Sumanta_88744's avatar
Jun 10, 2016
Solved
Universal Persistence with X-forwarder
Hi Experts
Can I use Universal persistence using x-forwarder with i-rule? I would have each x-forwarded IP stick to the same back-end pool member. Will this work? Can you please share code? Any other options to be enabled on the virtual server, I already have type set as standard vs.
Regards,
Sumanta.
  • A formatted version of the "Per VS" rate limiting. You can apply the same irule to all standard VS using UIE persistence.
    when RULE_INIT {
        set static::maxReqs 3;
        set static::timeout 60;
            set vs [URI::basename [virtual]]
            if { [HTTP::header exists "X-Forwarded-For"] } {
                set client_IP_addr [getfield [lindex  [HTTP::header values "X-Forwarded-For"]  0] "," 1]
                set client_IP_addr [IP::client_addr]
            if { ([HTTP::method] eq "GET") and ([class match [string tolower [HTTP::uri]] ends_with $vs_URI_LIST_TO_LIMIT] ) } {
                whitelist
                if { [class match [IP::client_addr] equals $vs_ips_whitelist] }{
                   return
                set getcount [table lookup -notouch "$vs_$client_IP_addr:[HTTP::uri]"]
                if { $getcount equals "" } {
                    table set "$vs_$client_IP_addr:[HTTP::uri]" "1" $static::timeout $static::timeout
                    if { $getcount < $static::maxReqs } {
                        table incr -notouch "$vs_$client_IP_addr:[HTTP::uri]"
                        reject
            persist uie $clientip
    when HTTP_RESPONSE {
        persist add uie $clientip
