RAQS's avatar
RAQS
Icon for Cirrus rankCirrus
Oct 28, 2020
Factory Reset
Hi Team,
Hope all of you are doing good.
I am planning to do factory reset of BIG-IP.
Can you please let me know the process and precautions to do this activity.
regards,
RAQS
    • RAQS's avatar
      RAQS
      Hi Mayur,
      Thanks for reply. I have been through this article.
      But still issue with F5, its in Inoperative mode , GUI stuck in configuration utility restarting. I did all
      possible troubleshooting but no luck. Its BIG-IP 4000 and on 11.6 version.
      Regards,
      Raqs
      • you performed all the steps from the K article?
        do you get anything on the CLI?
        what does the /var/log/ltm say?
  • Looks like your version is hit with the bug - https://support.f5.com/csp/article/K17368
    I'd suggest you to see if you can do a mcpd forceload and then do a reboot to see if the box comes up properly and loads the config. Try your luck. If not engage F5 support.
    • RAQS's avatar
      RAQS
      Thanks Jaikumar for reply, will
      upgrading it to stable version fix the issue ? Currently i am in 11.6 and it’s BIG-IP 4000 series.If so then which will be the good version to upgrade.
      regards,
      RAQS
      • jaikumar_f5's avatar
        jaikumar_f5
        Icon for Noctilucent rankNoctilucent
        I see your planning to repurpose this box by setting it with default config. If I were you surely I'll try my options with above. Since the solution is just a point fix, it should be an easy upgrade.
        Also some suggestions, you can go to grub menu and see if there's other images and boot with them. Then install new image in your desiring volume and boot back. It's all troubleshooting you gotta to do to resolve. Options are many !!!​
