Edouard's avatar
Edouard
Icon for Cirrus rankCirrus
Jul 17, 2019
Solved
vcmp system factory default
Hi Gents,
I need to factory reset a host that has 3 guests in the host. Can you advise how I can reset all to factory default deleting those guests as well.
Thank-you.
  • Hi
    If you completely clear the configurations and files in vCMP host, which is ucs, certificate, ISO..etc.
    Probably, clean installing is the best.
