Marty_Baxter_14's avatar
Marty_Baxter_14
May 27, 2014
Help modifying HTML content with an iRule
Hello,
I need help changing the HTML in the http response. Specifically in the line below I need to change the ../ to /es/aw/fleet/
I have tried the following code which did not work (no errors - but content was not modified): when HTTP_REQUEST {
 disable server side compression
HTTP::header remove Accept-Encoding
 disable stream for requests
STREAM::disable
when HTTP_RESPONSE { STREAM::enable
STREAM::expression {@../@/es/aw/Fleet/@} }
What am I doing wrong?
Thanks!
  • JG's avatar
    JG
    Try this:
        STREAM::disable
        if { [HTTP::header exists "Accept-Encoding"] } {
            HTTP::header replace "Accept-Encoding" ""
         STREAM::enable
        if { [HTTP::header value Content-Type] contains "text" }{
            STREAM::expression {@\.\./@/es/aw/Fleet/@}
            STREAM::enable
