Ed_Martens's avatar
3 years ago
Solved
Using shared object with BigIP
Just a "stupid" question:
Is there a reason  NOT to use Shared object address list's with a VS?
In contrast  using  multiple VS configurations (when only destination address is the difference).
Like to hear you thoughts
  • Please lookup your /config/bigip_base.conf for the ACL related configuration objects.
    The shared objects concept may significantly reduce the number of configuration objects, i.e. mixing IPv4/IPv6 source/destination addresse in lists. Same story for destination ports.
  • When using shared objects some ACL mechanisms are applied in the background.
    In the past I saw some issues there (especially in the context of route domains), which seem to be fixed in the current TMOS v15.1.5.1.
    • Ed_Martens's avatar
      Ed_Martens
      Icon for Cirrus rankCirrus
      Hi Stephan,
      Thanks for the response. This is the same version we are running at the moment 😉
      • StephanManthey's avatar
        StephanManthey
