Anzine321's avatar
Anzine321
Icon for Cirrus rankCirrus
11 months ago
Solved
routing to splunk for asm logging
Hi
is it possible route to splunk via management not selfip ? what is pro and cons ?
if i have partition with route domain and should use self ip, should i used in commond partition or specific partition ?
  • Hi Anzine321​
    Yes, it is possible to send ASM (Application Security Manager) logs to Splunk via the management interface.
    Refer below article:
    K30729139: Sending BIG-IP logs to a specific Syslog server, via the BIG-IP's management interface
    Pros: It keeps logging traffic separate from production/data traffic.
    Cons: Management interface may have limited bandwidth and Not suitable for high-volume logging in large environments
  • Hi Anzine321​
  • Yes it is possible.
    You simply need to add a management route for your syslog server and allow the traffic in any firewall in between.
