Magnum_IP's avatar
Magnum_IP
May 03, 2011
Routing using the virtual command
I'm having a problem routing traffic using the virtual command on HTTPS and hope that someone can help.
I have everything working on HTTP I just can't get HTTPS to work.
Basically when a certain condition is met I want to change the URI and route the traffic back into the same virtual server without the user seeing a change in URL i.e. I don't want to use a 302 redirect.
I have sanitised this but something along the lines of
if {$myVar < 1} {
HTTP::uri "/new.html"
virtual [virtual name]
I'm suspecting that the issue with HTTPS is to do with the Client/ServerSSL profiles, I was wondering if the ServerSSL profile was being used with the new connection to the virtual server. At any rate I get a Connection Reset.
Any ideas how I can solve or better troubleshoot my issue?
Regards,
fergu5
