Wil_Schultz_101's avatar
Wil_Schultz_101
Jan 30, 2007
Is it possible to use iControl to reset cached objects?
The bigpipe command I would like to either issue or emulate would be:
b profile http all ramcache exact uri /myuri/ host www.mydomain.com reset
Is this possible?
  • Check out the LocalLB::RAMCacheInformation interface. Specifically the evict_ramcache_entry() method.
    struct RAMCacheKey {
      String profile_name,
      String host_name,
      String uri,
      long maximum_responses
    void LocalLB::RAMCacheInformation::evict_ramcache_entry(
        in RAMCacheKey[] keys
    The maximum_responses member of the RAMCacheKey structure is ignored for the evict_ramcache_entry() command so just leave it at 0.
    BTW, This has been the product since v9.0.5.
    -Joe
