Adeola's avatar
Adeola
Nov 04, 2020
How to send duplicate UDP packet to more than one node
Hi All,
I have a scenario where I want to send duplicate udp packet to more than two node. I understand this is possible but can anyone point to the correct documentation or config sample of how it can be done?
Thanks,
Crown
  • Hi Crown,
    You can use "clone" command in iRule.
    https://clouddocs.f5.com/api/irules/clone.html
  • There are a number of ways - you can use clone pools to just spray it at layer 2, use the iRule clone command as above, use sideband/HSL if you want to change the content or ultimately use MRF to do complex and really groovy things such as having multiple sessions active etc
  • Adeola's avatar
    Adeola
    Thanks for your response so far.
    The problem I am going to have with spraying is, I have the node several hops away from F5. What will be the best way to address that?
    • PeteWhite's avatar
      PeteWhite
      In which case, an iRule with the clone command would make sense Eg when CLIENT_DATA { clone pool }
