AbuAhmad's avatar
AbuAhmad
Aug 04, 2021
Solved
Dropping connections after a specific part of URI
Hi There,
I need help to write an iRule that will drop the request for any request after this uri:
/xyz/web/apx/ pass this request but anything after that uri need to drop the request ( drop /xyz/web/apx/*)
tried this but it is not working:
  if { [HTTP::uri] contains "/xyz/web/apx/*" } {
     drop
Thank you in advance
  • oguzy's avatar
    oguzy
    Aug 05, 2021
    Hi AbuAhmad,
    I missed something sorry. Could you please try below one:
      if { [HTTP::uri] starts_with "/xyz/web/apx/" && not ([HTTP::uri] equals "/xyz/web/apx/") } {
         drop
  • oguzy's avatar
    oguzy
    Hi AbuAhmad,
    If the uri starts with /xyz/web/apx then you can use the following irule:
      if { [HTTP::uri] starts_with "/xyz/web/apx/" } {
         drop
    Otherwise your irule is almost correct. Just remove the asteriks at the end of the uri.
    Have a nice day.
  • Thank you Oguzy for the quick response,
    I tried this before but it drops the connection that I need to keep:
    https://host.name.com/xyz/web/apx/ << need this to still function including the "/" at the end but anything after that "/" should be dropped.
    Thats why I tried the "/*" as wildcard at the end as I don't have list of all the directories that comes after that but need to block all of them.
    Any ideas will be highly appreciated.
    • oguzy's avatar
      oguzy
      Hi AbuAhmad,
           drop
  • Thank you Oguzy so much for your help, this one worked as requested. I added to it "HTTP::respond 403" instead of "drop" to give a meaningful message.
    The client came back saying they can't block everyone passed apx/ :(
    So I am going to use data groups to block certain directories until they provide the full list.
    Thanks again for the help Oguzy.
