"Cpu utilization over 300 seconds is 100%" - Question
Hello,
I've got a question. Why does the message below appear in var/log/ltm file every 5 minutes? In comparison GUI graphs or "top" don't indicate any load at all - CPU utilization below 10%.
/var/log/ltm ...notice chmand[16603]: 012a0005:5: Cpu utilization over 300 seconds is 100%, exceeded log level 80%
Platform BIGIP 2000s V11.3 HF7
Thanks!
- What_Lies_Bene1
The chmand daemon relates to chassis/hardware monitoring as well as AOM (if present).
You might try
to see if that fixes the issue (or even a reboot) but considering the critical functions of this deamon, you might just want to log a call with F5 support immediately.bigstart restart chmand - nitass
Employee
fyi. it is bug 428706.
bug 428706 False positive 'Cpu utilization over 300 seconds is 100%, exceeded log level 80%'
- What_Lies_Bene1
Thanks Nitass. Good to know.
- nitass_89166
Noctilucent
- What_Lies_Bene1
