maming_125132
Mar 10, 2013upgrade from v9.4.7 to v10.2.1 issue
Hi all, i'm wondering if i can upgrade F5 LTM 1600 from v9.4.7 to v10.2.1 directly? but not from v9.4.7 to v10.1.0 then v10.1.0 to v10.2.1?
another question,i have to install hotfix and 10.2.1 patches both in inactive patition?
If i install the patch with "--format=volume" option,does that mean the whole disk will be formatted into one partition or some what like HD1.1 ,HD1.2? I'm confused.
Thanks for your reply!
Ming Ma from China.
- maming_125132
anybody could provide me with some kind suggetions? - maming_125132
anybody could provide me with some kind suggetions? - nitass
Employee
i'm wondering if i can upgrade F5 LTM 1600 from v9.4.7 to v10.2.1 directly? but not from v9.4.7 to v10.1.0 then v10.1.0 to v10.2.1?yes, you can.
sol13845: Overview of the supported BIG-IP upgrade paths and upgrade planning reference
http://support.f5.com/kb/en-us/solutions/public/13000/800/sol13845.html
another question,i have to install hotfix and 10.2.1 patches both in inactive patition?yes
If i install the patch with "--format=volume" option,does that mean the whole disk will be formatted into one partition or some what like HD1.1 ,HD1.2? I'm confused. i never installed hotfix using image2disk (i usually use b software or tmsh install sys software command). anyway, normally --format will format whole hard disk (not only one partition).
sol12513: Installing hotfixes using the image2disk utility does not return the status of the installation
http://support.f5.com/kb/en-us/solutions/public/12000/500/sol12513.html
sol11033: Managing BIG-IP version 10.1.x and 10.2.x hotfixes on systems using the partitions disk formatting scheme
http://support.f5.com/kb/en-us/solutions/public/11000/000/sol11033.html - maming_125132
Hi,nitass
Thanks a lot for your professional and kind tips! That helps me great!
I'll try,If i can make it, i will give the results.
Thanks again!
Ming Ma from China. - nitass
Employee
if i were you, i would format (i.e. --format=volumes) and install 10.2.1 first (e.g. hd1.1) and then install 10.2.1 with hotfix on another partition/slot (e.g. hd1.2) using b software or tmsh install sys software command. please make sure you backup 9.4.7 ucs before installing 10.2.1.
by the way, why don't you upgade to 10.2.4 latest hotfix? - maming_125132
Hi nitass
Thing went well except some little problems.
I didn't format the whole disks,i did backup configurations,and i kept v9.4.7,and upgrade another HD to 10.2.4 with hotfix to HF5.
when i install HF5 for v10.2.4,i doesn't work accortding to SOL11033,so i upgraded v9.4.7 in HD1.1 to version 10,then installed HF5 for v10.2.4 with "bippipe sofware".
The who process went smoothly,and both of my F5 1600 is ready now.
Ming Ma from China
