26-Nov-2020 22:19
i have upgraded to 15.1.2 . after upgrade snmpwalk is not working from standby to active device.
its work fine with version 14.1.x .
while testing i have added allowed list IP also.
error :
Timeout: No Response from x.x.x.x
26-Nov-2020
23:59
- last edited on
04-Jun-2023
21:10
by
JimmyPackets
Have you try to restart the SNMP daemon ? there's a bug on the snmp request on 15.1.2
https://cdn.f5.com/product/bugtracker/ID936125.html
restart sys service snmpd
Regards
27-Nov-2020 00:18
yes i restarted snmpd service...still not working i tried same command in version 14 and version 15.1.0 its works fine.. only on version 15.1.1 and 15.1.2 is not working.
27-Nov-2020 00:22
Can you give me you snmpwalk command for syntax check ?
27-Nov-2020 00:37
snmpwalk 2.9.22.1 -v2c -c SNMPCOMLAB system
27-Nov-2020
00:42
- last edited on
04-Jun-2023
21:10
by
JimmyPackets
if you run this command below on your F5 BIG-IP, it's work's ?
snmpwalk -v2c -c SNMPCOMLAB localhost system
27-Nov-2020 00:59
yes it works
local host work ..but remote host is not working...i added the remote host in the allowed list
27-Nov-2020 01:05
snmpwalk -v-c SNMPCOMLAB 25.96.225.4 bigipSystem
Timeout: No Response from 2.9.5.4
27-Nov-2020
01:08
- last edited on
04-Jun-2023
21:10
by
JimmyPackets
if you try to test a snmpwalk on remote host, you need to add IP Address of the host :
snmpwalk -v2c -c SNMPCOMLAB x.x.x.x MIB
27-Nov-2020 01:11
not working...
27-Nov-2020 01:11
Timeout: No Response from 25.96.225.4
27-Nov-2020 01:17
the command works fine with version 14.1.2.3 and 15.1.0.3 but its not working with 15.1.1 and 15.1.2
27-Nov-2020
01:32
- last edited on
04-Jun-2023
21:10
by
JimmyPackets
Check that the IP Address configure in allowed-list on host 25.96.225.4 is actually the management address of your F5 BIP-IP from which you send your snmpwalk.
tmsh list sys snmp allowed-addresses
27-Nov-2020 01:35
if the allowed-list is well configure, send ticket to support F5 maybe you're facing with a bug on 15.1.2.
20-Jan-2022 15:55
Did you ever come to a resolution on this issue. We are facing this exact same issue. The only difference being that ours our brand new i5800s on 15.1.3. All SNMP config/allowed addresses/community config is good. works from localhost but not on the mgmt ip
Note: the local attempt works on 127.0.0.1, but not on the mgmt IP when testing locally, leading me to believe that the daemon is not listening appropriately to connections from that interface.
20-Jan-2022 20:30
Hi Brian,
its bug ID969737 - snmp requests to the management address receive no response from the BIGIP if v2-traps are used
https://cdn.f5.com/product/bugtracker/ID969737.html
to fix you can used the below one
you can move v2-traps configuration to traps then it will work.
v2-traps {
/Common/IAS_PREPROD_1 {
community SNMPTRAPLAB
host 104.28.131.21
/Common/IAS_PREPROD_2 {
host 104.28.131.22
/Common/IAS_SAMPLICATE {
host 101.96.128.22
to
traps {
host 104.28.131.21
host 104.28.131.22
/Common/IASS_SAMPLICATE {
host 101.96.128.22
