mika's avatar
mika
Icon for Cirrus rankCirrus
Jul 28, 2020
redirect path irule f5
Hello!
I have three hosts ( www.abc.com /.www.aze.fr / www.qsd.fr ) with the same path and i want redirect all the paths to a new path for all hosts
My irule:
if {
  [HTTP::path] contains "/abcd"
 or [HTTP::path] contains "/yyyyyyy"
or [HTTP::path] contains "/xxxxxx"
or [HTTP::path] contains "/zzzzzz"
     HTTP::redirect "/fin_participations.html"
But my irule it's not good, have you suggestions to achieve my goal please!!
Thank you ^_^
  • Hi mika,
    	if { [string tolower [HTTP::uri]] ne "/fin_participations.html" } {
    		HTTP::redirect "http://www.abc.com/fin_participations.html"
    • mika's avatar
      mika
      thank you for your reply, but I cannot apply this rule because I have another url with the same hosts that I don't want to redirect to this page, i want redirect just some path not all.
      • You can use switch statement or datagroup.
        Switch:
        	switch -glob [HTTP::path] {
        		"/abcd*" -
        		"/yyyyyyy*" -
        		"/xxxxxx*" -
        		"/zzzzzz*" { HTTP::redirect "http://[HTTP::host]/fin_participations.html" }
        Datagroup:
        Create a string datagroup.
        /abcd
        /yyyyyyy
        /xxxxxx
        /zzzzzz
        Datagroup irule:
        	if { class match [HTTP::path] contains dg-name } {
    • mika's avatar
      mika
      Hello, thank u for your reply, i created a datagroup which contains all path, and i used
      LTM Policy refer attached image but i have the same probleme.
      Best regards
