Technical Forum
Pool with Range of ports
THE_BLUE
Cirrus
Cirrus
I have VS which listen to port 443 and 80 , mapped to pool which listen to rang of port ex 1000 - 2000
in this case i have create pool with * services port ( any) and associated with i rule. Does the below correct?
TCP::local_port is the correct one? or not?
when CLIENT_ACCEPTED {
        if { [TCP::local_port] => 1000 and [TCP::local_port] <= 2000 } {
            return
        else {
        reject
0 REPLIES 0
