kimhenriksen's avatar
kimhenriksen
Nov 08, 2023
Solved
permanent resize of /var/
Hi all!
I´ve been reading these two articles.
https://my.f5.com/manage/s/article/K34126971
https://my.f5.com/manage/s/article/K52061353
Are any of them a permanent fix for low diskspace of /var/ ?  Or will we/I have to redo it after every upgrade?
/Kim
  • There doesn't seem to be a permanent solution that survives an upgrade. However from version 16.0.0.0 the /var partition is increased by 50%. Maybe that will work for you. On the other hand, what's eating your diskspace on /var?
