preslav_ilevski's avatar
Dec 05, 2018
LCD stuck in "Updating Firmware"
Hi, f5 guys,
I updated f5 i5800 before several days from 12.1.2 to 13.1.1.2, and on the LCD I see a message:
Updating Firmware
This can take up to 30 minutes...
Please do not interrupt!
It's like there is an issue with the LCD.
I can access the device through SSH, but can not see anything related in the logs. The display doesn't allow any touch activities...
I tried to check what is the problem here (in DevCentral) and find a proposal to restart service "fpdd" (as I understood this is "Front Panel Display Daemon"), but there is no such service:
[root@F5-BIGIP-Host-1:Active:Standalone] config  tmsh show sys service  | grep fpdd
I perused all the services, but didn't find anything known to me...
Any ideas about this behavior?
Regards,
Preslav
  • Guys, anyone think the solution of this problem?
    I have 3 F5 2800 with this problem.
  • In this situation, I'd open a support ticket with F5. That being said, from your SSH access does it appear to have completed the upgrade? Can you login as admin via a browser?
  • Hi, Alan,
    Via SSH and HTTPS (through a browser as admin) the access is ok, and yes, the upgrade seems completed, everything is normal except the front panel LCD - it's stuck, and there is no change for several days...
    I am wondering how to fix the LCD issue.
    Regards,
    Preslav
  • Yes, Alan,
    I executed:
    for i in 0 1 2 3 4 5; do lcdwarn -c "${i}" 0; done
    and there is no change...
    For the reboot I want to be sure that will no failed. .
    Regards,
    Preslav
  • In that case, I'd open a support ticket with F5 since it sounds like you've done everything you can at this point. Let us know what happens, good luck! =)
  • ayhatu's avatar
    ayhatu
    Hi Guys,
    I get the same error. İ2600 after upgrade 13.1.0 > 14.1.2.2.
    Can you help with the solution?
