jparri's avatar
jparri
Apr 18, 2022
Solved
big-iq stuck running evaluation task
we an Big-IQ evaluation task that is now stuck in running status and we need to delete. Is there a daemon we could restart to clean this, without a reboot? We put in a ticket to F5, but only found possibly root cause. Id like to see if I can just restart a service or call a particular API to force remove that task if possible?
Has anybody seen this? BigIQ 8.1
    Could you try to run this command:
    bigstart restart restjavad
    This may change the status to FAILED and allow the deletion.
    If not, you could try restarting all daemon with the command:
    bigstart restart.
    Hope it´s work.
    bigstart restart.
    Hope it´s work.
    • jparri's avatar
      jparri
      thank for the response Sebastiansierra. I will try to restart restjavad first. IS it safe to do that during day with limited interuption or wait during maintenance window?
  • Hi again,
    If you restart the restjavad All BIG-IQ functionality stops, The core function of the BIG-IQ system is provided by way of restjavad, which implements all of the REST APIs. so if the Big-IQ is core in your company I recommend you restart it in a window maintenance.
    • jparri's avatar
      jparri
      I figured, just wanted to confirm. I appreciate the quick response! I'll reply back on here later with results. Thank you!!
