GavinW_29074's avatar
GavinW_29074
Feb 07, 2012
HTTP_RESPONSE not firing
Hi there,
I'm using the ProxyPass v10 iRule to perform some path rewriting on some of our VIP's...
However we seem to be getting some sporadic issues whereby the HTTP_RESPONSE event isn't being triggered when the request is being processed.
This results in the site breaking as all the resource paths etc aren't being re-written by the ProxyPass irule...
An example debug log is:
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/HandleErrors : Processing HTTP_REQUEST at Priority 20...
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/HandleErrors : $maintenance_mode = 0, $ssl_error = 0, $failure_result = ''
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/CacheControl : CacheControl HTTP Request at Priority 50:
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/CacheControl : HTTP Request for Host: 192.168.151.15 URI: /home.faces
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/CacheControl : GET Method, enabling Cache
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/HandleErrors : Processing HTTP_REQUEST at Priority 750...
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/HandleErrors : $pool_error = 0
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/HandleErrors : Passed error checking... Continuing...
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Processing ProxyPass HTTP_REQUEST
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Not In Maintenance mode. Continuing...
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Virtual Name = /Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, $vname = portal.comportal3.test.card.co.uk, $cname = portal, $clname = ProxyPass_portal
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: HTTP connection
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Data Group ProxyPass_portal found.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: $ppass = '/ /CommercialPortal'
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: ProxyPass_ value = / /CommercialPortal
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Clientside: Path starts / Host Clientside=192.168.151.15, Path Clientside=/.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Serverside: Host Serverside=192.168.151.15, Path Serverside=/CommercialPortal.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Appending / to Path Serverside.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Found Rule, Original Path=/home.faces, Client Host=192.168.151.15, Client Path=/, Server Host=192.168.151.15, Server Path=/CommercialPortal/
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Using default pool /Common/comportal3.test.app/comportal3.test_pool
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: $bypass value = 0
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Continuing with rest of HTTP_REQUEST block.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/CacheControl : Cache_Request for Host: 192.168.151.15 URI: /home.faces
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Processing HTTP_REQUEST_SEND block.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: New Host=192.168.151.15, New Path=/CommercialPortal/home.faces
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Inserting header: X-Forwarded-For: 192.168.100.208
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/CacheControl : HTTP Request for Host: 192.168.151.15 URI: /CommercialPortal/javax.faces.resource/style.css.faces;jsessionid=8c584e5692cb13a77d7628839ebb?ln=commercial/css
AS you can see it's quite happily processing upto the HTTP_REQUEST_SEND block, but just receives no HTTP_RESPONSE.
However the browser appears to receive a response and moves onto requesting some of the non-rewritten resources. E.g. on the last line where it still contains 'CommercialPortal'...
Relevant config:
gavinw@actint-star-f501(Active)(/Common)(tmos) list /ltm virtual comportal3.test.app/portal.comportal3.test.card.co.uk_http
ltm virtual comportal3.test.app/portal.comportal3.test.card.co.uk_http {
app-service /Common/comportal3.test.app/comportal3.test
destination 192.168.151.15:http
ip-protocol tcp
mask 255.255.255.255
pool comportal3.test.app/comportal3.test_pool
profiles {
Caching_CommPortal { }
HTTP_Rewrite { }
oneconnect { }
stream { }
tcp-wan-optimized { }
wan-optimized-compression { }
rules {
ProxyPass
SplunkHTTP
CacheControl
CatchErrors
HeaderStripping
MaintenancePage
UnavailablePage
HandleErrors
snat automap
vlans-disabled
gavinw@actint-star-f501(Active)(/Common)(tmos) list /ltm profile web-acceleration Caching_CommPortal
ltm profile web-acceleration Caching_CommPortal {
app-service none
cache-uri-exclude { /home.faces }
cache-uri-include { .* }
cache-uri-include-override none
cache-uri-pinned { /javax.faces.resource/* }
defaults-from optimized-caching
gavinw@actint-star-f501(Active)(/Common)(tmos) list /ltm profile http HTTP_Rewrite
ltm profile http HTTP_Rewrite {
app-service none
defaults-from http
redirect-rewrite matching
gavinw@actint-star-f501(Active)(/Common)(tmos) list /ltm profile one-connect oneconnect
ltm profile one-connect oneconnect {
idle-timeout-override disabled
max-age 86400
max-reuse 1000
max-size 10000
source-mask any
gavinw@actint-star-f501(Active)(/Common)(tmos) list /ltm profile stream stream
ltm profile stream stream {
source none
target none
Any ideas what might cause this???
Cheers
Gavin
