mika's avatar
mika
Icon for Cirrus rankCirrus
Sep 24, 2020
Can't call after responding - ERR_NOT_SUPPORTED invoked from within "HTTP::host"
Hello,
I have a problems in my IRules the redirections http to https.
In the logs LTM i have this error:
 SO: the redirection don't work in some browser : for few minutes i get an error conexion reset.
Thanks for your feedback
BIG-IP 14.1.2.3
  • If the irule only makes the http to https better use the default F5 iRule _sys_https_redirect
    If not don’t forget the return in the line after the redirect and if you have that check if there are more than one iRule on the VS
    Also a good idea is to close the connection so I use most times
    HTTP::respond 302 noserver Location https://[HTTP::host][HTTP::uri]  Connection Close
    • mika's avatar
      mika
      Thank you for your anser,
      this is the IRule who i used and i have alwayse the same problems with all hosts.
        if { [string tolower [HTTP::host]] contains "mysite.com"} {
           if {[HTTP::has_responded]}{return}
           #log local0. "[HTTP::host] [HTTP::uri]"
          HTTP::respond 301 Location "https://[HTTP::host][HTTP::uri]"
          regsub -all {:\d*$} [HTTP::host] "" host
           HTTP::redirect https://$host[HTTP::uri]
           return
      • Hi mika,
        Would you try using the "HTTP::has responded" line, before if statement?
        	if {[HTTP::has_responded]} { return }
        	if {[string tolower [HTTP::host]] contains "mysite.com"} {
        		return
  • After a HTTP::respond or a HTTP::redirect must follow a return, both lines do more or less the same and F5 has a problem using the [HTTP::] values after a call like that
