skeenster's avatar
skeenster
Jan 28, 2021
TCL error Can't call after responding - ERR_NOT_SUPPORTED invoked from within "HTTP::host"
Hi
Just upgraded to 14.1.2.6 and had some iRules broken in the process. I am seeing error below but struggling to resolve.
Guess we are affected by this but none of the workarounds seem to resolve.
https://support.f5.com/csp/article/K23237429
Here is the irule that worked before upgrade:
ltm rule /Common/apples_pears_oranges {
 if { ([HTTP::host] eq "wwwapple.removed.com") && ([string tolower [HTTP::uri]] starts_with "/pears") } {
  HTTP::respond 307 Location "https://oranges.com[HTTP::uri]"
Any help would be gratefully appreciated. We have multiple irule applied and even policy doesnt fix.
skeenster
  • Hi skeenter,
    Add this line all affected iRules.
    if { [HTTP::has_responded] } { return }
    	elseif { [HTTP::host] equals "wwwapple.removed.com" && [string tolower [HTTP::uri]] starts_with "/pears" } {
    		return
  • Thanks for the reply this actually did resolved our issue once it was applied to all the required iRules on the virtual server.
    Is this fix also required for HTTP::redirect as these iRule appear to be working, but not sure if we need to update?
