01-Feb-2021 19:49
15-Apr-2021 22:32
We do apologize for any inconvenience caused by the reorganization of our document repositories. Sometimes there is just no easy way to move a lot of web content without creating intervening links to take you from the old repository to the new. As the message you received states, all historical DevCentral Wiki content (which includes documentation for the various F5 APIs, such as iControl REST and iRules) has been migrated to F5 CloudDocs. The iControl REST API docs specifically can be found here. Otherwise, a quick click on the link provided in the 404 Not Found message should take you to where you need to go.
15-Apr-2021 22:32
26-Apr-2021
17:03
- last edited on
24-Mar-2022
01:10
by
li-migration
- If you have the originating source for this failure we can either fix it as a one-off OR it'll illustrate a new/different pattern for which we can institute a wider search/replace or (occasionally) a more robust solution - within platform constraints.
