Robert_Richmond's avatar
Robert_Richmond
Aug 16, 2007
Wildcard VIP with iRule defining Port
Thanks for taking the time to read this.
I am trying to load balance cisco secure traffic through a vip. And here are my options:
A) Create a separate VIP with a separate pool for each port (49, 1645, 1646, 1812, and 1813)
B) Create a single VIP with a separate pool for each port, and use an irule to correlate the incoming port with the pool.
C) Create a single VIP with a single pool, using an iRule to initiate the connection to the pool member on the inbound port.
I know how to do options A and B. I am looking for examples or tips on how to write the iRule for option C...
Any suggestions, help, or tips would be greatly appreciated.
Thanks!
Rob
  • Option C doesn't need an iRule. If you set the pool members up with a wildard port as well, the ltm by default will forward the inbound port.
  • Maybe I should have clarified. I want to drop traffic not on the ports specified... security.
  • Still don't need a rule if you use a packet filter, but if you want a rule, this should work for you assuming your pool members have their port set to any:
    class myRadius_class {
      "1645"
      "1646"
      "1812"
      "1813"
    when CLIENT_ACCEPTED {
      if { ([TCP::local_port] == 49) or [matchclass [UDP::local_port] equals $::myRadius_class ] } {
        pool myPool
      } else { discard }
  • I used data group lists instead of classes and tweaked yours to the irule below (probably unnecessary, but a good excercise for a new irule-er). When I apply the rule, the vip is looking for both tcp and udp profiles to be applied (due to the matchclass statements). Being configured as a standard vip, this is not possible. Will I need to configure this as a 'Performance (Layer 4)' type vip with '*All Protocols' selected?
    When a client is accepted, if the port matches a port in the corresponding protocol data_group_list then forward to the pool. Else discard.
    if { [matchclass [UDP::local_port] equals $::ciscoSecureUDP ] or [matchclass [TCP::local_port] equals $::ciscoSecureTCP ] } {
    pool acs.deloitte.com_Wildcard
    } else { discard }
    Thanks,
    Rob
  • Yes, you'll need the performance l4 type to match both tcp & udp.
