Anush
Apr 05, 2016Viprion 2250 Blade - design question
I am going to setup a guest on viprion 2250 blade. thinking to use single core vs two cores since there would be around 40-50 vips only on that guest and don't want to waste resources. if I calculate memory then host will assign 3.05 gb to the guest and I think that's more than sufficient for guest with 50 vips. I don't know how to count cpu.
are you guys agree with me? thoughts? suggestions? what are advantage and disadvantages to use single core vs multi core?
- Venky
CPU usage will depend on virtual server type, features you are using. I think only way to get the the some baseline is by simulating your environment. - Paul_T_
As Venky said, this will heavily depend on your specific setup. I would personally avoid a single core setup if you are going to be doing any manipulation of HTTP requests. If you're just doing TCP load balancing, you *might* be okay.
