Samson's avatar
Samson
14 years ago
Trunk Between 3600 and OmniSwitch 9700
We currently have a functional trunk between the F5 3600 & a Cisco 2960G. The configuration is basic:
trunk Gateway-Trunk {
lacp enable
interfaces {
1.1
1.2
1.3
On Cisco:
interface Port-channel6
description Etherchannel to motdr-f53600-01 gateway
switchport trunk native vlan 21
switchport trunk allowed vlan 21
switchport mode trunk
interface GigabitEthernet0/20
description to motdr-f53600-01 1.1
channel-group 6 mode active
interface GigabitEthernet0/21
description to motdr-f53600-01 1.2
interface GigabitEthernet0/22
description to motdr-f53600-01 1.3
We are replacing multiple Cisco switches with this one 9700 so I need to get this to work.
The OmniSwitch has two options for creating aggregation groups, either static or dynamic. The Static configuration is pretty straightforward but the dynamic method appears to be the one that allows for LACP definitions.
I tried both, removing LACP from the F5 side and going with a static agg on the Omni and then going back to LACP on the F5 and with dynamic configuration on the Omni, neither of which worked.
Anyone ever done this successfully?
Thanks!
-Samson
  • Samson's avatar
    Samson
    Indeed it does:
    -> show 802.1q 1
    Tagged VLANS Internal Description
    21 TAG AGGREGATE 1 VLAN 21
    I believe there is a basic, simple, piece that I'm missing here ... I'm new to the Omni switches so... yea... fun.
