Anthony
Mar 29, 2022Truncating of a system variable - ASM reference
We are currently experiencing an issue where the ASM reference for a block is being truncated.
The response page has the code: "supportid":"<%TS.request.ID()%>" and this has always given the full number, however now it is dropping the last digit. Is there some upper limit to the characters this can display? Can the ID's be reset?
Any help would be appreciated as it is making finding a reported issue more difficult.
Thanks in advance.
Raise the support case. may be issue somewhere else.
