ravan's avatar
ravan
11 months ago
Solved
What happens if I activate only ASM without provisioning LTM?
Suppose I have a BIG-IP device licensed for both LTM and ASM, but under System > Resource Provisioning, only the ASM module is enabled and set to Nominal.
Would the system still perform load balancing across multiple pool members in this case, or do I need to enable the LTM module to support that functionality? Which functionalities will be disabled ?
Thanks in advance.
  • LTM functionality is not disabled by setting LTM provisioning to None. It just reduces the memory allocated to LTM-specific processes, but the core traffic management and load balancing features remain available as long as the license includes LTM.
    Refer: K17173140: Setting LTM Provision NONE does not disable LTM functionality
    • Juergen_Mang's avatar
      Juergen_Mang
      Icon for MVP rankMVP
      As I understand, the LTM functionality is there even you have not provisioned the module. It is enough that the license is activated to have full LTM functionality.
      The difference between licensed and provisioned is the reservation of memory for LTM.
