Johana23's avatar
Johana23
Jun 15, 2023
Solved
Provisioning r2600 equipment
Is it advisable to provision r2600 equipment with LTM, DNS, AWAF + IP intelligence licensing? o for 3 or more provisioned modules, higher equipment such as r4xxx must be used?
  • In my lab, if I want to use ALL modules, then I provision 8core+16Gb.  This is a lab with automation, couple dozen apps and minimal client traffic.
    The r2600 has 8 cores and 32Gb ram.  So, to answer you question, I don't think you will have any problems running those services on that hardware.  However, I would be very cautious about how much client load you put on the box and particularly how comprehensive the AWAF policies are.
    I suggest reaching out to your account team for a deeper analysis and capacity planning.
      • LiefZimmerman's avatar
        LiefZimmerman
        Icon for Admin rankAdmin
        I've pro-actively marked Ben_Novak 's answer as Solution. If you disagree Johana23 - feel free to un-select / provide some additional context to help others help. Thanks, Lief
    • Azim_IIPL's avatar
      Azim_IIPL
      Icon for Cirrus rankCirrus
      Ben_NovakHi dear,
      can we provision AFM with LTM on r2600 series. is that possible one of our customer is asking kindly your input is highly appricated
