ahddom's avatar
ahddom
11 months ago
PCI Compliance and ASM
We are building a system that is to be PCI complient.
The system will be hosted in segregated zone in the infrastructure... where we have:
  • Load balancer to receive the external traffic
  • Web server in the segregated zone (DMZ inside the segregated zone).
  • Application server in the internal zone of segregated zone.
In our Internet gateway and external DMZ, we have a F5/ASM that protects all exposed services (non-PCI for now). This protection includes SSL inspection and loggin to SIEM.
As part of the PCI requirements, we need to protect our exposed services through WAF.
In the same time we should not exposed CHD data to be plaintext... any solution from F5 ASM for this?
Or any other architecture recommendation?
  • F5 WAF’s “Data Guard” prevents sensitive data (e.g., credit card numbers, SSNs) from logging or leaking in responses. It masks or blocks CHD in HTTP responses and logs, meeting PCI DSS requirements for plaintext CHD exposure. Use SSL bridging to prevent plaintext CHD exposure on the network.
    Reference:
    K34154012: Configuring Data Guard detection patterns (12.x - 17.x)
    K8363: Using the Mask Data setting to protect sensitive data returned by the BIG-IP ASM
  • I would also add use separate partition and route domains to fully isolate PCI traffic from the rest.
    Maybe a different SIEM too.
