TomSu_93471's avatar
TomSu_93471
Feb 01, 2012
Simultaneous tcpdump capture for two different physical intf 1.1 and 1.2
need some help on tcpdump tracing topics. I want to trace two physicals 1.1 and 1.2
at the same time, but this seems not possible ?
1) one session goes ok:
[root@f5-1:Active] tmp tcpdump -s0 -ni 1.1:nnn -w /var/tmp/1.1.pcap tcpdump: listening on 1.1:nnn, link-type EN10MB (Ethernet), capture size 65535 bytes
2) but the 2nd one fails soon after starting:
[root@f5-1:Active] tmp tcpdump -s0 -ni 1.2:nnn -w /var/tmp/1.2.pcap tcpdump: listening on 1.2:nnn, link-type EN10MB (Ethernet), capture size 65535 bytes tcpdump: pcap_loop: Error: Interface packet capture busy
Trace on 0.0 works ok, however I don't see in there references to physical intf numbers, so it will be hard to see real traffic flow what is exactly what I need (STP BPDUs issue between Cisco and f5)
Any help on this topics appreciated,
Cheers
Tom
  • I want to trace two physicals 1.1 and 1.2 at the same time, but this seems not possible ? no, it is not possible.
    Trace on 0.0 works ok, however I don't see in there references to physical intf numbers, so it will be hard to see real traffic flow what is exactly what I need (STP BPDUs issue between Cisco and f5)is source mac address not usable?
  • Naresh_15230's avatar
    Naresh_15230
    Historic F5 Account
    1) Create vlan by associating interface like this
    [root@localhost:Active] config tmsh create net vlan int interfaces add { 1.1 }
    [root@localhost:Active] config tmsh create net vlan ext interfaces add { 1.2 }
    2) Now you can verify tcpdump for traffic in both the vlans simultaneously like this
    [root@localhost:Active] config tcpdump -ni /Common/int
    tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
    listening on /Common/int, link-type EN10MB (Ethernet), capture size 96 bytes
    In another session,
    [root@localhost:Active] config tcpdump -ni /Common/ext
    listening on /Common/ext, link-type EN10MB (Ethernet), capture size 96 bytes
  • this wont work then?
    1. system tcpdump –i (1.1, f5_trunk1, external, 0.0) –eXs 0 –w /var/tmp/dump.cap &
    2. system tcpdump –i (1.1, f5_trunk1, external, 0.0) –eXs 0 –w /var/tmp/dump2.cap &
    3. system fg
    4. ctl+c
    5. system fg
    6. ctl+c
    7. system tcpdump –r /var/tmp/dump.cap
    8. system tcpdump –r /var/tmp/dump2.cap
  • Hi Nick,
    as far as I understand it´s not a matter of running the commands simultaneously.
    Instead it´s a matter of replicating traffic on a physical interface and a limitation of the chipset.
    By now I never saw it working on a switch based F5 BIG-IP.
    Thanks, Stephan
