johnscr_45871's avatar
johnscr_45871
Dec 12, 2008
Simple match of URL based on regular expression
Hi
I am haveing some trouble with this simple Irule and was hoping someone could help. All I have to do is check the incomming URL and see if it matches a reg ex. If it matches the reg ex, then pass the request on to "PoolB".
The regular expression (as one of my devs has writtin it) looks like this:
(.*)?postcode=(.*)&email=(.*)
The incomming url will look like this:
http://www.bla.com/folder1/?postcode=POSTCODE&email=EMAIL
where POSTCODE is an actual postcode and EMAIL is an actual email address.
I know this should be simple but I just cant get it working??
Any help will be met with massive amounts of karma, respect, love and chocolate covered goodies.
  • hoolio's avatar
    hoolio
    Hi there,
    A string comparison would be more efficient than a regex. If you really want to check if the postcode and email parameters are in the URI in a particular order you could use [string match *postcode=*email=* [HTTP::query]] to perform the test. Else if you want to check if the query string contains the two parameters in any order you could do two checks ([string match *postcode=*email=* [HTTP::query]] or [string match *email=*postcode=* [HTTP::query]]) or parse the parameters using URI::query (Click here)
    Here is the first option:
          Check if the query string contains anything postcode anything email anything or anything email anything postcode
         if {([string match *postcode=*email=* [HTTP::query]] or [string match *email=*postcode=* [HTTP::query]])}{
             Query string matched, so use PoolB
            pool PoolB
             Query string did not match, so use PoolA
            pool PoolA
    Here is the second option which parses the query string for the actual parameter values and checks if they have a length. If you don't care whether the parameters have a value, you can remove the string length check on the values:
          Check if the query string contains the postcode and email email parameters with lengths
         if {([string length [URI::query [HTTP::query] postcode]] and [string length [URI::query [HTTP::query] email]])}{
            pool PoolB
            pool PoolA
    Aaron
  • So after some persistance I got this one to work. I hope its doing the correct thing, but initial testing looks OK.
    if {[HTTP::uri] matches_regex "(.*)?postcode=(.*)&email=(.*)"} {
    log "Landing pages on Pool B"
    pool uSwitchPoolB
