Ichnafi's avatar
Ichnafi
Feb 16, 2023
Solved
Change crypto master key with ansible not possible?
Hello fellow F5ers,
does anyone know a way to change the crypto master key on an LTM with ansible?
The TMSH command is:
modify sys crypto master-key prompt-for-password
the command is interactive and requires the user to repeat the passwort input two times.
Is it even possible to do this by using an ansible module?
Thanks for any advise
Ichnafi
