Bartek's avatar
Bartek
Icon for Cirrus rankCirrus
Apr 11, 2025
Replace stream if condition is met
Hi - I have an iRule i need to draft, however I can only test it once it drafted, by sending it to my customer for testing... bummer.
So the problem is - I need to inject my .js in the body of the response, but only if the script is not already injected (there is a valid reason for this, I promise).
My thinking process is based on this:
https://clouddocs.f5.com/api/irules/STREAM_MATCHED.html
The goal is:
1) Check if the body contains /js/app<10digits>.js
2) If it does - do nothing
3) If it does not inject /js/app.js just before closing </body> tag
or:
2) delete the /js/app<10 digits>.js
3) Insert /js/app.js just before closing </body>tag
I'm thinking option 2 might be simpler, please let me know if my thinking is good, and If possible suggest some more elegant solution
    STREAM::disable
    HTTP::header remove "Accept-Encoding"
when HTTP_RESPONSE {
    if { [HTTP::header exists "Content-Type"] && [HTTP::header value "Content-Type"] contains "text/html" } {
        if { [HTTP::header exists "Content-Length"] } {
            HTTP::header remove "Content-Length"
        STREAM::expression {
                =<script type="text/javascript" src="/secfense/js/eru-[0-9]{10}\.js"><\/script><\/body>==
                @</body>@<script type="text/javascript" src="/secfense/js/eru-1744029915.js"></script></body>@
        STREAM::enable
I'm not sure whether multi expression STREAM::expression is a thing... Will this work?
  • I'm trying to avoid collecting the payload.
    I actually realized I know exactly how does the payload look like without my insert... So i made a simple stream::expression that adds to the known payload.
    something like this:
        STREAM::disable
            STREAM::expression {@"module"></script></body>@"module"><script type="text/javascript" src="/secfense/js/eru.js"></script></body>@}
            STREAM::enable
