iRule's avatar
iRule
Icon for Cirrus rankCirrus
Mar 08, 2023
Solved
replace part of URI for specific URL and pass remaining
Dear Community,
I need to replace only specific part of  URI i.e "/abc/defg/" with "/uvw/xyz/"  in a URL. All other URLs should not be altered.
"/abc/defg/" will appear in the begning of URI
For example:
From: https://bbcc.com/abc/defg/v1/derh/user-cases/ profile/morning
To:      https://bbcc.com/uvw/xyz/v1/derh/user-cases/ profile/morning
All Other URLs should not be alerted and sent to pool without modification in URI.
Regards
  • iRule It should be the following and any other additions can be added in a similar manner. You might consider speaking with the application team and have them perform the corrections on the server as this should only be done as a last resort in an iRule.
    when CLIENT_ACCEPTED priority 500 {
        set DEFAULT_POOL [LB::server pool]
    when HTTP_REQUEST priority 500 {
        if {[string tolower [HTTP::uri]] starts_with "/abc/defg/"} {
            HTTP::uri [string map {"/abc/defg/" "/uvw/xyz/"}[HTTP::uri]]
            pool pool_web
        } elseif {[string tolower [HTTP::uri]] starts_with "/123/456/"} {
            HTTP::uri [string map {"/123/456/" "/78/910/"}[HTTP::uri]]
            pool pool_web
        } elseif{[string tolower [HTTP::uri]] starts_with "/asdf-asdf/"} {
            HTTP::uri [string map {"/asdf-asdf/" "/lkjh-lkjh/"}[HTTP::uri]]
            pool pool_web
            pool ${DEFAULT_POOL}
  • I tried following iRule but it results in URIs starting with "/abc/defg/working fine and all other URLs stopped working which are not starting with "/abc/defg/".
    if {[HTTP::uri] starts_with "/abc/defg/"} {
    pool pool_web
    • iRule I have made some slight modifications to the iRule but I don't think it will resolve your issue but are best practices.
              pool pool_web
      If you can provide additional detail as to what exactly isn't working for the additional URLs we might be able to assist further.
      • iRule's avatar
        iRule
        Paulius All other URLs that are not starting with "/abc/defg/" are stopped and I am getting connection reset error. Kindly provide an updated iRule.
