REDIRECTION ISSUE
set userhost [HTTP::host]
if { $userhost == "testdomain.org"} {
set userhost "www.[HTTP::host]"
HTTP::redirect https://$userhost[HTTP::uri] }
It works GREAT. My issue now is I need to be able to add subdomain.testdomain.org, testdomain.net, etc. Creating a 2nd rule doesn't help. I tried combining them and separating them with an 'or' but got errors. I tried downloading the iRule editor but the download link seems to just loop back to where you start. I need this rule because the SSL cert on the F5 is only for www.testdomain.com and the rule prevents the cert error that makes end-user think there's some issue. Please help, I'm an iRule idiot.
Jhd
- JonasD_46068
I tried to use an elseif to add the subdomain.testdomain.com and it is appending www.subdomain.testdomain.com which does NOT exist. So I am close but no cigar. I see 'why' it did it but I"m not sure how to fix. Here's what I tried that didn't quite work:
elseif { $userhost == "ml.testdomain.org"} {
HTTP::redirect https://$userhost[HTTP::uri] } - Colin_Walker_12Historic F5 AccountI think what you're looking for is something like:
when HTTP_REQUEST { set userhost [HTTP::host] if { $userhost equals "testdomain.org"} { set userhost "www.[HTTP::host]" } elseif { $userhost equals "ml.testdomain.org"} { set userhost "[HTTP::host]" } elseif { $userhost equals "testdomain.net"} { set userhost "www.[HTTP::host]" } HTTP::redirect "https://$userhost[HTTP::uri]" }
Note that the way you're manipulating userhost changes depending on what it was set to coming from the client. If you see subdomain.testdomain.org, you're not going to want to prepend a www to it. If you see just testdomain.org or testdomain.net, then you will.
Make sense?
Colin - Parveez_70209
Hi Colin,
Here is the detailed issue:
We have HTTP plus HTTPS Virtual-Server, where anyone who will hit:: http://shop.test.com/broutlet or http://shop.test.com/broutlet/* , it should redirect to http://outlet.lenovo.com/broutlet/br/pt/ to be accurate.
Where /* can be anything, for now only http://shop.test.com/broutlet/ redirection is happening to http://outlet.lenovo.com/broutlet/br/pt/ but not with http://shop.test.com/broutlet/*(just one for example : http://shop.test.com/broutlet/br/pt)
Regards PZ
- Parveez_70209
Hi Team,
The below Irule is working good, sorry for the confusion:
if { [string tolower [HTTP::uri]] starts_with "/broutlet" } { HTTP::redirect "http://olet.domain.com/broutlet/br/pt/" } }But this is giving 302 redirection, it should give 301 redirection, how my Irule will look like.
Thanks and Regards Parveez
- nitass
Employee
you have to use HTTP::respond instead of HTTP::redirect.
HTTP::respond
https://devcentral.f5.com/wiki/irules.HTTP__respond.ashx
