tthomaPXL's avatar
tthomaPXL
Nov 03, 2023
Solved
issue with irule redirecting with # string
https://support.abc.int/supportnet/application.jsp#support/32
https://pxl.saas.supportsystems.com/assystnet/application.jsp#services/48
trying to create an irule to redirect the top site to the bottom site however the "#" is being interperted as another command and giving us an error. any way we can redirect the uri with the # sign?
  • In addition to what Paulius says, you can try the iRule below.
        # Disable the stream filter by default
        STREAM::disable
        # LTM does not uncompress response content, so if the server has compression enabled
        # and it cannot be disabled on the server, we can prevent the server from
        # sending a compressed response by removing the compression offerings from the client
        HTTP::header remove "Accept-Encoding"
        if { [HTTP::uri] starts_with "/f5/anchor_link_redirect" } {
            set href [b64decode [URI::query [HTTP::uri] href]]
            if { $href equals "https://support.abc.int/supportnet/application.jsp#support/32" } {
                HTTP::redirect "https://pxl.saas.supportsystems.com/assystnet/application.jsp#services/48"
            else {
                HTTP::redirect $href
    when HTTP_RESPONSE {
        if { ([HTTP::header "Content-Type"] starts_with "text/html") } {
            STREAM::expression {@</title>@</title>
        <script>
        document.addEventListener(`click`, e => {
          const origin = e.target.closest(`a`);
          if (origin && origin.href.indexOf('#') > -1) {
            const base64_href = btoa(origin.href);
            window.location.href = '/f5/anchor_link_redirect?href=' + base64_href;
        </script>@}
            STREAM::enable
    For more info on how to use this iRule see: https://community.f5.com/t5/codeshare/python-script-to-test-if-a-f5-big-ip-is-vulnerable-to-cve-2023/ta-p/323614
    Have fun,
         --Niels
        STREAM::disable
            else {
        <script>
        </script>@}
            STREAM::enable
    Have fun,
         --Niels
