jomedusa's avatar
jomedusa
Icon for Cirrus rankCirrus
Jan 08, 2026
Same LTM Monitor applied to different Pools with Common Nodes
We have a several nodes that are used multiple pools and each of the Pools has the same monitor associated with them.  My question is will each node be monitored separately for each pool even though the monitor is the same?  We are going through some clean up and trying to validate that the monitoring in place is not causing more traffic than needed.  We have also started to alert on when a node fails monitor and have started to notice that they are failing not due to a bad response but due to no response.
Thanks in advance,
Joe
  • Hi jomedusa​
    Yes monitor will be exetuted for every pool.
    You could apply the monitor on node level though and it will be executed only once per period.
    • LiefZimmerman's avatar
      LiefZimmerman
      Icon for Admin rankAdmin
      If this reply solved your problem jomedusa​ - please consider Mark as Solution - to help others find this answer faster in the future.
      Cheers!
