mnocciolino's avatar
mnocciolino
5 years ago
Reboot secondary HA after ConfigSync
Hello,
We have 2 Big-IP Viprion in HA, SO: BIG-IP 11.4.1 Build 637.0 Hotfix HF3
Today we delete one irule and ConfigSync from "Sync Device to Group" with "Overwrite Configuration"
Synchronization failed and the secondary rebooted, we don't know why rebooted.
After the secondary started we ConfigSync again with no problem.
I attach a zip file with the logs
Could be any of these bugs?
https://cdn.f5.com/product/bugtracker/ID468514.html
https://cdn.f5.com/product/bugtracker/ID476544.html
thanx for help.
  • There are many reason to re-start the other unit. I would suggest you to review the logs for more information.
  • What log? (ltm, audit?....) Where can I get information to guide me to do a troubleshooting?
    • Samir's avatar
      Samir
      Icon for MVP rankMVP
      Search the logs file or generate the qkview and upload in ihealth.
      ==> /var/log/ltm
      ==> /var/log/tmm
      ==> /var/log/audit
      If still having difficulty, open support case for more help.
