suthomas1's avatar
suthomas1
Apr 01, 2021
Solved
Secondary persist method
Goodday all,
when & how does secondary or backup persistence method gets applied. Is it only when primary method fails, if so how does ltm determine to apply seconday method.
thanks in advance.
  • https://support.f5.com/csp/article/K30483109
    When F5 detects the primary persistence is no​t working, fall back would be applied. e.g. cookies are blocked/not supported in client browsers if primary is cookie, SSL session I'd changes frequently and primary persistence method is SSL.
