adiezma_1656's avatar
adiezma_1656
Apr 16, 2012
Problem with the "PROXY LDAP" iRule
Hi!
I have a Problem with the "PROXY LDAP iRule."
In history, we have an LDAP directory, where the user can change their profile at any time.
Works perfectly except When Needs to modify a photograph of a user profile. When That Happens, error says "Can not Connect with LDAP server" and does not change the profile picture.
An LDAP administrator tells me that the only difference Between a change in profile and a change in profile picture, Is That the petition "ldap_modify" is Done with binary data.
Any idea?
Thanks a lot.
Antonio.
  • Hamish's avatar
    Hamish
    Hmm.. Both ldap messages are going to be encoded. So they're really all 'binary' data... What does a tcpdump of the traffic show?
    H
  • Hamish's avatar
    Hamish
    It's possible that the encoding for the length of the message and/or msgid is slightly different when updating the (Larger) photo data... IIRC (Sorry it's been 2 years since I looked at this iRule) the LDAP_PROXY iRule makes some assumptions when decoding certain fields
    H
  • I have capture with wireshark, but I can not send the archive.cap
    Regards
    Antonio
