Problem ProxySSL with two pools.
I have a VS with ProxySSL enabled (profile SSL client and server), and two pools with HTTPS (A_pool and B_pool). I configure the A_pool as default pool in VS and works correctly. But when I change to B_pool, through a iRule, show a error. How can I change the default pool through a iRule?
Very thanks.
- Jad_Tabbara__J1
Hello,
Could you share your irule code.
- Cesar_01_134968
Hi JT,
Attach my iRule,
when HTTP_REQUEST { if { [HTTP::path] contains "/B/" } { pool B_pool } else { pool A_pool } }
Thanks.
- Jad_Tabbara__J1
It seems that your code is correct.
I tried this code and it works for me
when HTTP_REQUEST { if {[HTTP::path] contains "jta"} { log local0. "my_pool_a is selected for path [HTTP::path]" pool my_pool_a } else { log local0. "my_pool_b is selected for path [HTTP::path]" pool my_pool_b } }Have you applied the irule to your VS ?
Remark: you can remove the "default pool" configuration from the "ressources" and just apply your irule and try again.
You can also check your log in /var/log/ltm
Regards
