epaalx's avatar
epaalx
Icon for Cirrus rankCirrus
Feb 14, 2012
pool member monitor versus pool monitor
Hi F5'ers,
(in configuring a pool using CLI/tmsh) which monitor is used to determine state of a pool if member-specified monitor is different to pool-specified monitor? Are both used or member's monitor is used?
Stretching this, what if none of the member-specified monitors are the same, what should pool-specified monitor be?
R's, Alex
  • which monitor is used to determine state of a pool if member-specified monitor is different to pool-specified monitor? it is monitor at pool member level.
  • it is monitor at pool member level.
    Ok, but this doesn't quite make sense - pool-specified monitor determines pool's status, where as member-specific monitor determines member's status - (logically) the latter doesn't imply the former unless there's only one member in a pool.
    Answer to my second question would clear it up, if you could volunteer.
  • hoolio's avatar
    hoolio
    You can have a monitor assigned to the pool. You can also have monitors assigned directly to a member. If a pool member has a member-specific monitor it will not use any pool monitors.
    In the example below, 1.1.1.1:80 will be monitored using only the http_1.1_monitor. All other pool members without a member specific monitor will inherit the monitor(s) associated with the pool. So 1.1.1.2:80 will be monitored by the default http monitor. You can have more than one monitor associated with both the pool and/or the specific pool members.
    pool my_pool {
        members {
            1.1.1.1:80 {
                monitor http_1.1_monitor
                session monitor-enabled
            1.1.1.2:80 {
        monitor http
    For both pool monitors and pool member-specific monitors, you can separately specify a minimum number of monitors which need to succeed:
    pool my_pool {
       monitor all min 2 of http tcp http_1.1_monitor
       members {
          1.1.1.1:80 {
             monitor min 1 of http_1.1_monitor gateway_icmp
          1.1.1.2:80 {}
          1.1.1.3:80 {}
    In this second example, 1.1.1.1 will be checked using http_1.1_monitor and gateway_icmp. As the Availability Requirement (min X of ...) is set to 1 1.1.1:80 will be marked up if either the http_1.1_monitor or gateway_icmp monitors succeed.
    1.1.1.2:80 and 1.1.1.3:80 will both be checked by the pool monitors http, tcp and http_1.1_monitor. As the Availability Requirement is set for 2 the pool members will be marked up if two or more of the monitors succeed.
    So why would you want to do this? Your web servers might require the host header being set with a server-specific value. If that were the case, you could create one custom HTTP monitor for each and assign each to the corresponding pool member instead of on the pool. Other than that, I haven't seen many customers use member-specific monitors.
    Aaron
  • So, basically pool attribute "monitor all" specifies monitors used when member attribute "monitor" is set to value "default", correct?
    And, these pools (below) are equivalent?
    pool pool1 {
     monitor none
     members {
      1.1.1.1:80 {monitor1}
      1.1.1.2:80 {monitor2}
    pool pool2 {
     monitor monitor3
     members {
    pool pool3 {
     monitor monitor2
     members {
      1.1.1.2:80 {}
  • Not sure if this behavior has changed now. When I apply node-specific monitor and NOT pool monitor, my pool remains blue. Shouldn't pool be green if each member in node-view shows each member green?
    Does it mean there is one monitoring going on for each node from node-monitor perspective and another monitoring going on from pool's perspective?
    Here are my definitions:
    ltm pool prd-pl-vsp_mdm {
        members {
            prd-pl-vsp1:any {
                address 172.26.225.100
                priority-group 1
                state up
            prd-pl-vsp2:any {
                address 172.26.225.101
                state up
        min-active-members 1
        monitor Server-Monitor-8443
    ltm node prd-pl-vsp1 {
        state up
    ltm node prd-pl-vsp2 {
        state up
    Thanks.
    • epaalx's avatar
      epaalx
      Yes.
      Although counter-intuitive, even if a node's monitor detects node as unavailable, LTM will continue to monitor the member using monitor defined in the pool - see K7118.
    No. Node specific monitors can only mark a pool member down. The posts above are regarding pool member monitors, which are a different object. Using your code, if you had this:
        members {
            prd-pl-vsp1:any {
                priority-group 1
                state up
            prd-pl-vsp2:any {
                state up
        monitor none
    This would work correctly and should bring up the pool.
