Amresh008's avatar
Amresh008
Jul 21, 2020
NTP Sync issue
I have gone through the article K01250526 in attempt to fix the issue but no joy.
I am using 14.1.2.3.0.0.5 but getting error as shown in the article. My LBs are behind the same interface on the firewall and have tried using it's IP as the NTP server, and also with Gateway for the self IPs firewall but still get same error. The LBs report time skew error of 155 and 224 seconds.
Any resolution other than upgrade ?
  • Hi Amresh008,
    That article refers to earlier s/w versions. Do you match all conditions as described in the article?
    I would start your investigation with this article:
    https://support.f5.com/csp/article/K10240
    If you require further assistance on this thread please provide output of the following:
    #ntpq -c peers -c as
    Kind regards
    Ben
