Pihu_294516's avatar
Pihu_294516
May 03, 2018
Solved
Need help with VIP creation
Hello Folks,
I am looking for some assistance in creating a VIP for autodiscover application, the cert provided to me is webmail.xxx.com and I am asked for SSL Bridging , my question is- Will this cert work for autodiscover application? or I need to request for specific cert for autodiscover?
Thanks in Advance.
  • Is autodiscover.xxx.com included as a SAN on your certificate? If it is included then your cert may well work.
    • Anju's avatar
      Anju
      Hi Ryan, Thank you for answering that for me.I noticed that the cert does include autodiscover.xxx.com in the SAN. SO, that will be good to go. However, after importing the file it does gives an error message when that cert was called in a ssl profile. What import type I should be using? Do I use PKCS or certificate type ? Tried both but not working.
      I have attached the screenshot with the error message, can anyone explain me what does that mean? what wrong I am doing here?
      TIA...
    • Ryan_80361's avatar
      Ryan_80361
      Heya,
      I usually convert to PEM format and then paste the cert/key into the appropriate fields. I find it helps to avoid errors.
    • Anju's avatar
      Anju
      TIA...
    • Ryannnnnnnnn's avatar
      Ryannnnnnnnn
      Heya,
  • You can also consider creating a wildcard cert with wildcard SAN names. Ex: cn:.google.com san:.autodiscover.google.com, *.yahoo.autodiscover.google.com, *.yahoo.com
