Vikneswaran_709
Dec 01, 2017Mapping of SSL Certificate, Key & Chain
I have a requirement to get the mapping of Certificate, Key & Chain for a profile. As i have many numbers of profile, is there a way to get a report from f5 LTM which is running on 12.1.2
Yeah, You can use basic unix command in
. Below command will help you to publish output & play in excel sheet.tmshCommand will pull value SSL-Profile name , Cert, Key, Chain_cert
tmsh list ltm profile client-ssl one-line | awk '{print $4" " $9" " $19" " $17}'Hope it will work for you.
