Nitin2014_16246
Aug 17, 2015Keep-Alive timer & Idle-timeout value:: LTM ver. 11.5 HF3
Whats the default Keep-Alive timer value & Idle-timeout value for ver 11.5? 1. LTM to Nodes (Pool Members). 2. LTM to Client.
- tatmotiv
This depends on the profiles you are using (tcp, tcp-lan-optimized, fastl4...). You can see all the timer settings for the profiles in use in the web interface.
