Roy_Jee's avatar
Roy_Jee
Mar 29, 2021
ISO 11.x.x Uplaoding issue in LTM 1600
Hi Folks,
I am facing an issue while uploading ISO file to LTM 1600."Its not Visible on GUI".I have checked at CLI its present there but unable to load/install it.Please someone suggest what's the matter here.I have upload the file using winscp and GUI both.
  • What does 'tmsh list /sys software image' shows? You could upgrade to a newer version using the CLI. Maybe the newer version fixes the issue you are facing.
  • Thanks for replying...
    IT shows the previous uploaded images.....but not showing the new uploaded image which is latest and i wish to install.
    • And what shows the command 'ls -la /shared/images/'? Are user, group and permissions consistent? What about the size of the images?
      [root@bigip:Active:Standalone] config # ls -lha /shared/images/
      total 2.2G
      drwxrwxr-x.  3 root   tomcat 4.0K Mar 17 10:46 .
      drwxr-xr-x. 39 root   root   4.0K Mar 24 12:46 ..
      -rw-r--r--.  1 tomcat tomcat 2.2G Mar 17 10:45 BIGIP-14.1.4-0.0.11.iso
      drwxr-xr-x.  2 root   root   4.0K Apr 24  2020 tmp
      Is there enough diskspace? Try 'df -h /shared/images/'
      [root@bigip:Active:Standalone] images # df -h /shared/images/
      Filesystem                         Size  Used Avail Use% Mounted on
      /dev/mapper/vg--db--vda-dat.share   15G  2.7G   12G  20% /shared
      Not sure if your version also uses SELINUX. Try 'ls -laZ /shared/images/'. Check SELINUX permissions.
      [root@bigip:Active:Standalone] images # ls -laZ /shared/images/
      drwxrwxr-x. root   tomcat system_u:object_r:default_t:s0   .
      drwxr-xr-x. root   root   system_u:object_r:default_t:s0   ..
      -rw-r--r--. tomcat tomcat system_u:object_r:default_t:s0   BIGIP-14.1.4-0.0.11.iso
      drwxr-xr-x. root   root   system_u:object_r:default_t:s0   tmp
  •  df -h /shared/images/
    /dev/mapper/vg--db--sda-dat.share.1
                          30G 6.6G  22G 24% /shared
     ls -ltr /shared/images/
    total 6513500
    -rw-r--r-- 1 root  root     798744576 Jul 18 2013 BIGIP-10.2.1.297.0.iso
    -rw-r--r-- 1 tomcat tomcat  1379663872 Aug 18 2013 BIGIP-11.3.0.2806.0.iso
    -rw-r--r-- 1 root  webusers 1932533760 Mar 25 09:51 BIGIP-11.6.5.3-0.0.2.iso
    -rw-r--r-- 1 root  webusers        59 Mar 25 09:51 BIGIP-11.6.5.3-0.0.2.iso.md5
    NOw let me explain my query again.....above versions are visible on GUI i can see these image on GUI thus can istall too....but BIGIP-11.6.5.3-0.0.2.iso is not visible on GUI.
    • Try changing the ownership to tomcat. 'chown tomcat:tomcat BIGIP-11.6.5.3-0.0.2.iso'. And remove the .md5 file.
