Netmart's avatar
Netmart
Jan 03, 2025
show system - attribute values
After PSU has been changed values [power, temperature, voltage] remain at zero.
When issuing the command ‘show system ‘ an hour later, it seems that the value of these sensors have been updated. And the question, whether this behavior is expected? Is there an hourly health check running?
Model: r5600
# show system
At 3pm:
system health components component psu-1
hardware appliance/hardware/psu/psu1
  state name psu-1
  state health ok
  state severity info
        ATTRIBUTE  ATTRIBUTE  ATTRIBUTE
ATTRIBUTE NAME                                          ATTRIBUTE DESCRIPTION                             HEALTH     SEVERITY   VALUE      UPDATED AT
module:communication-error                              Module communication error                        ok         info       false      2025-01-03T15:01:33-05:00
psu:sensor:current-in                                   PSU Current In (A)                                ok         info       0          2025-01-03T15:01:33-05:00
psu:sensor:current-out                                  PSU Current Out (A)                               ok         info       0          2025-01-03T15:01:33-05:00
psu:sensor:fan1-speed                                   PSU Fan 1 Speed (RPM)                             ok         info       0          2025-01-03T15:01:33-05:00
psu:sensor:power-in                                     PSU Power In (W)                                  ok         info       0          2025-01-03T15:01:33-05:00
At 4pm:
# show system
  state name psu-1
  state health ok
  state severity info
psu:sensor:current-in                                   PSU Current In (A)                                ok         info       1.078      2025-01-03T16:00:01-05:00
psu:sensor:current-out                                  PSU Current Out (A)                               ok         info       16.875     2025-01-03T16:00:01-05:00
psu:sensor:fan1-speed                                   PSU Fan 1 Speed (RPM)                             ok         info       9440       2025-01-03T16:00:01-05:00
psu:sensor:power-in                                     PSU Power In (W)                                  ok         info       220        2025-01-03T16:00:01-05:00
  • Hi Netmart
    Did you check several times in the 1 hour interval?
    In principle it shouldn't be a problem
    can you check with
    tmsh show /sys hardware
    cheers
