Thiago_Morais's avatar
Thiago_Morais
Jan 11, 2021
iRule with HTTP::request and datagroup
Hi Guys,
I need to create an iRule that will check two conditions:
1) HTTP::request contain a specific word "test"
2) The source IP is a member of the Datagroup
I would like to create an iRule using only one if statement (one line) to check both conditions above?
Thanks in advance
  • Here, you can use logical AND operator to check both conditions and if both are fulfilled, set required actions.
    Below is IF statement for your reference.
    if { ([HTTP::host] contains "test") && ([class match [IP::client_addr] equals Allow-List]) }
    Hope it helps!
    • Samir's avatar
      Samir
      Icon for MVP rankMVP
      Add string tolower functions may help here.
  • I can use this irule inside a HTTP_REQUEST event? The HTTP_REQUEST event allows me to check the client IP address in datagroup?
  • Yes it should! I tested below iRule on my lab setup and it is working fine. You can try your iRule using above IF Statement and test.
    if {([HTTP::host] contains "test") && ([class match [IP::client_addr] equals Allow-List])} {
        pool TEST-Pool
    log local0. "Allowed client IP is  [IP::client_addr]"
        log local0. "Dropped IP is [IP::client_addr]"
    Hope it helps!
