Blue_whale's avatar
Blue_whale
6 years ago
Solved
Need help in adding Datagroup to existing Irule
Hi Team ,
I have below Irule which currently works for specific single source IP 10.10.10.1 ...I would like to add more IP using Datagroup , Could you please help me modify this irule .
I tried but I got error "variable reference required proceeding $"
Note : We have route domain configured and VIP is configured in route domain %70 .
Thanks in Advance :)
if {
                 ([IP::client_addr] contains "10.10.10.1%70") && ([string tolower [HTTP::uri]] contains "/cklauncher/")
                drop
elseif { [string tolower [HTTP::path]] equals "/" && ( [IP::addr [IP::client_addr] equals 10.10.10.1%70]) } {
# redirect the request
log local0. "issuing redirect request to [HTTP::host][HTTP::uri] from [IP::client_addr]"
HTTP::redirect https://[getfield [HTTP::host] ":" 1]/ckpartner/
  • Hi,
    Any chances to same client IP address appears on different route domains on this iRule? Because I think IP data group won't consider route domains on validation, but I'm not 100% sure. This way, I think working on data group type ip route domain number wold be noise optional.
    ltm data-group internal dg_my_ip_list {
        records {
            10.10.10.1%70/32 { }
        type ip
        if { [class match [IP::client_addr] equals dg_my_ip_list] } {
            if { [string tolower [HTTP::path]] equals "/cklauncher/" } {
                drop
            } elseif { [HTTP::path] equals "/" } {
    I hope it helps.
    Best regards.
  • Hi,
        records {
        type ip
                drop
    I hope it helps.
    Best regards.
    • Blue_whale's avatar
      Blue_whale
      Hi Cjunior,
      I need help here .
      With Datagroup I want to block access to both the uri's /cklauncher/ and /ckpartener/ and anything else should be accessible .
  • Hello,
    Changing this part, will that work for you?
    if { [string tolower [HTTP::path]] equals "/cklauncher/" or [string tolower [HTTP::path]] equals "/ckpartener/" } {
                drop
    Regards
      Blue_whale
      I will try this , Thank you
        records {
        type ip
            drop
